Best 19" LCD for R2000 or - ?
MrE
Hey Ya'll, I've been reading up as much as I can on the subject.
I know 17" have the same resolution, but I prefer text to be a bit larger, so the 19" would be easier on my eyes.
I will be playing games/movies etc. but also Dreamweaver/Flash/Fireworks..
I know the contrasts should be high 500:1 or more is good !?
Fast Response rate, ..+/- 8ms
And brightness should be around 250/300 cd/m2 + is good !?
DVI !
Have my eye on the 19” BenQ FP91G+ R2,299
"A" Grade Panel
8ms Response Time
Contrast: 550:1
Brightness: 250cd/m2
Dual Input: D-sub & DVI (VGA/DVI Cables Included)
Dot pitch: 0.294
Display colors: 16.2 million with dithering
i Key Auto Adjustment
or
The BenQ FP91GX 19" R2,399
Resolution: Native SXGA (1280x1024)
Viewing Angle 140/130
Contrast: 550:1
Brightness: 270 cd/m2
Gray-to-Gray response time: 4ms
Display colours: 16.2million
DVI/D-sub inputs
Can anyone suggest any another brand or model that would be as good but even a little cheaper?
Oh, ye I am a CT dweller..
jjtoymachine
Incredible Connection have a Acer 19' widescreen for R2500.
CMV 19' widescreen going for R2200 at a local PC place in JHB
MrE
ya, you see, those acer's only had D-sub/analogue inputs, which is apparently a fairly big disadvantage clarity-etc.-wise compared to DVI. The CMV, again D-Sub.
Looks, interesting:
PACKARD BELL MAESTRO 190W
19" Wide display
16/10 aspect ratio
1440 x 900 maximum resolution
300 Nits brightness
Contrast 500:1
8ms response time
DVI & 2 x analogue inputs
Integrated speakers
1 Year warranty
R 2,799.95
but the ACER AL1916W does have the edge price-wise, but apparently also has a backlight-leaking problem that annoys on darker games and movies, and the colours are a bit anemic.
jjtoymachine
Yeah i would try get DVI...but I wouldnt kick myself if it didnt fit my budget. Not much wrong with D-Sub :)
MrE
Analogue input not worry you Antithesis?
Sharp Images? How games + movies perform?
AntiThesis
Not in the least MrE. With the new monitor everything is damned crispy and oh so purty. Monitor easily goes from almost incandescent white to the dark required for them thar scary games.
Plus, it just looks swell on my desk. It's just waiting for two more of its kind to come up and join it.
MrE
Antithesis, ..on the IC website, the wide screen, and your monitor are the same price, ..did you have the choice, and if yu didn't, would you choose the widescreen now, if you did have the chance? :)
AntiThesis
I did have the chance but widescreen always bugs me because of the low height. The width is awesome but it just looks wrong somehow.
:D
You know you want to buy the Ferrari one :p
MrE
True true, that factor has been on my mind! :)
I think I will just stick with a normal 19" ...
Will do Hannibal! ;)
MrE
Opinions?
Gigabyte:
GD-1903DPI
Max. resolution: 1280 x 1024@75Hz
Horizontal Frequence: 31-80KHz
Vertical Frequency: 60-75Hz
Pixel pitch: 0.294 mm
Contrast ratio: 800:1
Response time: 8ms (gray to gray)
Viewing angel: 170(H), 170(V)
PC connector: D-sub 15pin, DVI-D
Speaker: 2.5W + 2.5W
R1,995
Hanns-G® CY199D 19" Black LCD - 1280x1024 SXGA - 8ms Response, 2x 2W Speakers, 250cd/m2 Brightness, 700:1 Contrast. VGA + DVI
R1495
Hanns-G® HU196 19" Black/Silver LCD - 1280x1024 SVGA - 8ms Response, 2x 2W Speakers, 250cd/m2 Brightness, 700:1 Contrast, VGA + DVI
R1495
Any help in choosing!? :)
jjtoymachine
Not 100% sure but I think Hanns-G use the CMV pannel. I have seen them at Corex before quality seems fine, not too wild on its stand though.
PeekNPoke
I've got the BenQ FP91G-X ... and for the price I'm loving it to bits ;)
James
I got the Acer 1916W and it is the bomb. Had no issues with it and am loving it, and this is from a gamer.
AntiThesis
See one of the things I absolutely love about the packard bell is they seem to have cottoned onto the fact that I DON'T WANT SPEAKERS on my monitor. I have a big 5.1 system... what the hell do I want with a couple of 2.5w speakers?
The benQ actually looks very nice. Always been kinda suspicious of them as a brand for some reason. Don't think it's at all logical but there it is.
MrE
true, I would love to go for the Hanns-G, but that design is troubling me, I think I may just always wish that I would've gotten something a bit prettier.
And ya, 2x1W, or even 2x2.5W speakers are a bit ridiculous..
Anyone know know anything bout these?
Proline LM928 19" LCD, SXGA, 1280x1024@75Hz, 8ms, DVI, Super Slim Bezel
R1,802
Could be a good compromise between price and looks etc..
Edit: Update ..ok scratch that, it seems it has a 25ms response!
