BFG Tech® GeForce® 7950 GX2 1GB
Person
Banned
For those South African's that want the Tech 1st... we are going to get it to you. From the 5th, we have stock of the following card. If you want a price your are going to have to Pm me.
UPC NUMBER: 876758000551
BFG Tech PART NUMBER: BFGR7950GX21GBEI
Romance copy:
Designed for extreme HD gaming, the BFG GeForce® 7950 GX2 combines the power of two GeForce 7950 graphics processing units (GPUs) on a single graphics card. This unbelievable graphics horsepower, along with a 512-bit memory interface and an astounding 1GB of fast GDDR3 memory, enables an incredibly smooth, ultra-realistic gaming experience at resolutions up to 2560x1600.
Shelf Tag Bullets
• Designed for Extreme HD Gaming
• Built for Microsoft® Windows® Vista™
• True Lifetime Warranty with Free 24/7 Technical Support
• Connectors: 2 Dual-Link DVI-I, HDTV
• HDCP Enabled
Free extras:
BFG Teflon® Slick Pads - These pads fit over existing mouse feet and instantly reduce the friction between a mouse and mouse pad — a must for serious gamers.
BFG T-Shirt
Specifications
Processor: Dual NVIDIA® 7950 GX2
Interface Slot: PCI Express®
Memory: 1GB GDDR3
Core Clock: 500MHz
Memory Clock: 1200MHz
RAMDAC: Dual 400MHz
Vertices/sec: 2200 million.
Memory Bandwidth: 76.8GB/second
Maximum Analog Resolution at 32-bit color: 2048x1536@85Hz
Maximum Digital Resolution at 32-bit color: 2560x1600@60Hz
Software Included: NVIDIA® ForceWare® Drivers
Minimum System Requirements
• CPU with 1.8GHz processor speed or higher
• 256MB of RAM
• Microsoft Windows XP
• CD or DVD-ROM drive
• 35MB available hard disk space 50MB for full installation)
• A 450W PCI Express complaint system power supply unit with a combined 12V current rating of 27A or more
• A PCI Express compliant motherboard
• A vacant x16 PCI Express slot
• A vacant slot adjacent to the PCI Express x16 slot. This board occupies two slots: The x16 graphics slot and the slot below it
• A 6-pin PCI Express supplementary power connector or two available 4-pin molex hard disk drive power connectors (smaller floppy disk drive connector is not sufficient)
pupa
Banned
Why just blurp it, Shy? Give a good price else I import it meself!
lilDeath
Holy **** damn, mutha a$$....jeepers!!! :eek:
Price, my dear person??
How bouts some SLI for this card heh? ;)
Person
Banned
oh I will, dont worry.
lilDeath
It isn't out yet... not enuff time yet for a preview, dude...
don't think they wanna write about how big and bling the boxes are... :D
just some rants from people available. :D
Will have to be patient, dude
mccrack
lilDeath said:
It isn't out yet... ok well, out by a coupla hrs but methinks not enuff time yet for a review, dude...
I did say preview
Jah
DX10 is going to have to wait till vista, think its only next gen of cards
lilDeath
hhhmmm quad SLI ...
does that mean it is going to use 4 PCIE slots... seeing as one card takes up 2 slots...!!! :eek:
lilDeath
think its a different card in the link from Jah...
the memory clocks speeds are different from Person's one:
600 MHz vs 1200MHz
useless
lilDeath said:
hhhmmm quad SLI ...
SLI is overrated and too expensive...all i want is a DX10 compliant card in 2007.
Jah
Same memory clock, the 1200MHz actually refers to the data rate. You need to double the memory clock to get the data rate.
Jah
Its confusing cause different people give different values. If you look at that same article when they show the cards they benchmark against, they use both ways of showing it.
NVIDIA GeForce 7900 GTX 512 MB GDDR3 650 MHz Core 800 MHz Memory
NVIDIA GeForce 7600 GT 256 MB GDDR3 550 MHz Core 1.7 GHz Memory
think it has to do with the memory bus, but not sure
