Billion 5102G help needed - Billion Tech guy???
mR Yellow
Hey guys,
My connection to BF2 has been dropping since i've got this new Billion 5102G router. Previous Marconi worked fine...but it sucked compared the Billion.
I ran the diagnostics test and these are my resulys:
>> Testing Ethernet LAN connection .... PASS
>> Testing ADSL Synchronization .... PASS
>> Testing ATM OAM segment ping ... FAIL
>> Testing ATM OAM end to end ping ... FAIL
>> Ping Primary Domain Name Server ....PASS
>> Ping www.yahoo.com ....PASS
I get a FAIL on ATM OAM test! Can someone help? I don't know if this is a important? How can i fix it?
Could someone pls help. Thanx
mR Y
terencevs
As Far as I remember my router also fails those two steps.
Darth Garth
Telkom uses PPPoE (Ethernet) and not PPPoA (ATM) for their ADSL setup so this test will fail.
You can ignore this error.
BILLION Tech
BillionSA Representative
Company Rep
Hi
The reason for the failure is not the router that fails this ATM test. Telkom does not support the ATM loopback test that the router is trying to do. So it will fail cause it is not supported on any of the DSLAM's.
Surv0
Does your whole connection drop then come back up? check that your disconnect timeout value is set to 0...
mR Yellow
Thanx, but where do i find that option on the billion 5102G? I looked but can't find it :eek:
|tera|
Master of Messengers
I think it's here: I just got this router today, so I could be wrong,
click interface setup>internet>check at the connection settings that it's set to always on(recommended) and the connect on demand is 0
Hope that helps ;)
mR Yellow
Hope that helps ;)
Thanx. Mine is set up like that.
