Mini review time !
Specs:
Syetem
Operating System Android 6.0
CPU CPU:MTK6753 Octa Core, 1.3GHz
GPU GPU:Mali-T720
RAM 3GB
ROM 32GB
Extended Storage 32GB
Display
Screen type OGS, IPS, Capacitive Touch Screen ,Dragontrail 2 Glass
Screen size 5.5 inch
Screen resolution 1920 × 1080 pixels FHD
Screen color 16000K colors
Network
Wireless connectiveity GSM, 3G, 4G, GPS, WiFi, Bluetooth
Frequency 2G: GSM 850/900/1800/1900MHz
3G: WCDMA 900/2100MHz
4G: FDD-LTE 800/1800/2100/2600MHz
Bluetooth Yes 4.0
WiFi Yes
GPS Yes, GPS, AGPS,GLONASS
Camera
Camera type Dual cameras (one front one back)
Back camera 13.0MP (interpolation 16.0MP) F2.0 aperture,dual flash,auto focus
Front camera 5.0MP (interpolation 8.0MP)
Video recording Yes
Connectivity
SIM card slot Dual SIM Card, Dual standby
In the box you find the phone pre-fitted with screen protector and basic cover. It has a spare screen protector also. Comes 2amp charger, usb cable and OTG cable to use the phone as powerbank also.
First think you notice while using this phone it is heavier than your normal phone, this is good thing in this regard as the 6000mah battery is quite heavy
This phone has no bloatware, just a skin over the stock android 6.
Even know phone has a lower end mediatek chipset it is faster than P8 with no lagg at all! The gps locks on instantly no problem with it also. I think android 6 is optimized to use all the cores, this is not little big setup with the cpu cores, all 8 cores is 1.3ghz A53 cores to be used at the time same. The OS does down clock and disable the cores when not in use.
The phone is slow installing apps after it is downloaded from playstore, noticed same problem with P8 when I upgraded to android 6.
Camera is good, but not as good at the P8.
Hoping to see how long battery last today, 7 hours with 1amp charger only got phone to 95% lol
Screen is good, just good as my P8! At least I can run it at higher brightness now, because of this massive battery! P8 chocked even at low brightness
I hope they release 8000mah or 10000mah phone with high end specs, maybe with mediatek x20 deca core! Would love a 10core with a 10000mah battery!
Will post some pics soon!
