kwaggawerner
Hey Guys,
I need some help, I'm wracking my brain to find a solution to A. power on and off a DOL starter, and B. Also get the status (on/off) when triggered locally (physically).
Wiring a simply contact to power on is dead simple, but a DOL started has a seperate ON and OFF, wiring in a NO and NC configuration respectively.
Am I overthinking it? Is it as simple as using a ESP32/Shelly/Sonoff over the A1/A2 to trigger on and off? Or should I use a 2-sw/input device one for discreet on and off? - If so can I use tasmota to recognise a seperate on and off signal in a single device?
I'd ideally like to use Shelly for this project.
Any help would be apreciated.
