I just went through the installation process and here is some tips & knowledge I can share:
1) The inverter needs to supply both active power and reactive power. So make sure you have know the rating of the inverter's apparent power (measured in Volts-Ampere) and not just active power (measured in Watts)
2) Look at your house' wiring. You need to be able to split your circuits into essential and non-essential circuits. If you are lucky, all of that can be done on the DB, but you might need to rewire some elements if you are not lucky.
3) My setup on battery (which I think is good) is to have a normal depth of discharge at 30%. That means that day-to-day I only use 70% of the battery's capacity and keep 30% in reserve for power failures. If there is a power failure my setup recharges the battery back up to 30% from the grid. Your battery needs to be sized with that in mind.
4) Make sure your inverter can feed your non-essential circuits if there is excess power!
5) You need to look at both the battery's capacity AND its power delivery ability. It doesn't help if your battery can't feed the inverter fast enough or absorb solar fast enough!
6) Smart switches and home automation pair well with solar. So make sure you can connect your inverter to Home Assistant. Some things you only need to run when you have excess power - e.g. pool pump.
7) Plan how many strings you will have for your solar panels. Longer strings might be slightly cheaper but if one panel in a string is slightly shadowed you lose a lot of generation capacity. Shorter strings mean more effective harvesting.
Mistakes I made:
1) I didn't overprovision solar panels. If you can, do it. You want to maximize your average power generation and not your peak. If you don't use all the peak power then it is no biggy, but having extra generation in the mornings and evenings and cloudy days takes pressure of your battery and grid usage. Solar panels themselves are by far the cheapest component of the installation.
2) I didn't plan properly on how they should do the wiring at my DB which sits in a kitchen cupboard. It doesn't look all that great.
Decisions I made that maybe cost a bit of extra money but I thought was well worth the cost.
1) I went with Victron inverter setup. It is slightly more expensive because it is not an integrated unit, but rather your MPTT, inverter, fuse-box, power meter and reverse flow stop etc are all separate units. Victron pairs well with my Home Assistant, and if something breaks I can replace a component at a time.
2) I went with an installer with 20 years track record. From what I understand that in America a lot of installers went bust and dealing with warranties became a PITA. That being said I got a good price for the gear I bought from them, but some installers will cut corners to give better prices.
