Ok, for the networking guru's out there.
My problem is as follows:
I have multiple systems and network sorage devices (all gigabit capable with cat 6 cables) all centrally connected to an 8 port gigabit switch which is then connected to an 10/100 ADSL router. Whenever sending anything over the network the speed seems to hit that 10MB (100mbit) cap due to everything going through the router. Is there any way of making a direct connection to the NAS and transfering at higher speeds without connecting the cable directly to the NAS causing the pc to lose internet connectivity or fiddleing with cables.
I realise what I ideally need is a gigabit capable router, but to find one for anything below 2k that has ADSL built in is almost impossible, so I have put a hold on the upgrade.
All i want to do is utilise the greater bandwidth that gigabit provides whilst still maintaining my internet connection. Would think this would be possible with some sort of setting to stop data from being routed through the router.
Any ideas?
Any ideas?
