Unless you need 4k resolution at higher than 75hz refresh rates, that cable will be just fine..Can someone recommend me a display port cable or will this be good enough from takealot?
Takealot
www.takealot.com
Thanks.Unless you need 4k resolution at higher than 75hz refresh rates, that cable will be just fine..
Does anyone know where I can get a v1.4 DP cable? I've tried a few of the local shops, but no luck so far.
Check here: https://www.geewiz.co.za/search?controller=search&s=display+port+1.4+cable+lindy
I purchased this a few months ago for my 144hz monitor, excellent quality.
Lindy 36481 1m DisplayPort 1.4 Cable, Anthra Line
From the Lines cable connectivity concept developed by Lindy, Anthra Line DisplayPort cables are the professional choicewww.geewiz.co.za
