Cantenna - possible solution wind issues
Donovan
Hi guys,
After months of having a connection that drops when the wind blows, I took the step of having some pringles. I put the modem + pringles can on the antenna into the roof, stuck it in a packet to keep the dust off, directed it nicely then ran the network cable down to my router, and I've had no disconnects today. None - and it's REALLY windy.
It feels wierd, I still find myself looking out the window at the trees, hoping that I don't get dropped :)
My signal has improved from 3% with one light to around 12% with 2/3 lights. Ping time has dropped quite a bit - from 450+ms to 250ms average. Packet loss dropped from 12% to around 4%.
Jhbgirl and others, it may be an idea to try doing this - stick it in the roof. Oh, and I re-installed the new firmware and it works well now.
MrJones
Think I need to invest in some pringles... Why isn't some enterprising person importing the cantenna so that we can but it locally???
Please mommy make the bad man stop. (Bad Man = Sentech)
Donovan
Oh no wait... um, it did disconnect now now. So it's not a solution to everything, BUT, the wind is blowing all the time and surprisingly it's lasting more than an hour at a time. Usually it wouldn't even connect.
Robone
MrJones, I bought a cantenna when I was in the USA earlier this year, and it was an improvement on the ricoffy, pringles etc. and even tried a few other designer cans, but after still sitting with disconnects just when I needed a signal, I decided to spend the bucks and install a good dish antenna.
Sure I had fun experimenting, but adding it all up, It would have been better to spend that little bit extra and do it properly.
I am still hanging onto my cantenna in case of what, I don't know, but just in case.
My signal jumped from 12 odd % to 30 + % and no disconnects.
Razer0
hmm i read somewhere that if u can get the signal above 50 or so, the pings will improve. Right now i have no antenna and im at 33% or so, so will getting a satellite dish in place improve my signal thus getting better pings?
nonroker
that's one of those early "theories"
it's been proven to be utter cr@p
256k ... BAH..more like 25.6k
FSCK YOU Sentech!! [:(!]
arf9999
MyBroadband Member
I found the only real solution to the latency issue.
Resolving host 'www.sentech.co.za'
Pinging [66.18.65.124] x 4 with 32 bytes of data
Reply from 66.18.65.124 : bytes=32 : time=28 ms
Reply from 66.18.65.124 : bytes=32 : time=31 ms
Min=28 : Max=31 : Ave=30 ms : Packetloss = 0%
<b>Find another way of connecting</b>[;)]
-A
<i>Sold my soul to the great Satan: Telkom ADSL. Yes they're evil but still better than Sentech</i>
Robone
Okay you win
Reply from 66.18.65.124 : bytes=32 : time=131 ms
Reply from 66.18.65.124 : bytes=32 : time=90 ms
Reply from 66.18.65.124 : bytes=32 : time=150 ms
Reply from 66.18.65.124 : bytes=32 : time=111 ms
Min=90 : Max=150 : Ave=120 ms : Packetloss = 0%
But can you take it with you?
Can you download more than 3 gig? :) not sure if we can either.lol
Can you have fun taunting the orcs?
Come on you miss this don't you?
arf9999
MyBroadband Member
Robone,
Since my cancellation has not been finalized, I'm still taunting the orcs! I can download more than the 3G, it just costs a fscking fortune!
and yes, this forum is MUCH more interesting than the ADSL one....there's too much bleating about caps over there. They have no perspective [;)]
keithr
I get the following via smoothwall (signal 40%, but +-1.6kms on the rear end of single node tower 50 - Hurlyvale with 28dbi antenna)
PING 66.18.65.124 (66.18.65.124) from 66.18.86.80 : 56(84) bytes of data.
64 bytes from 66.18.65.124: icmp_seq=1 ttl=250 time=112 ms
64 bytes from 66.18.65.124: icmp_seq=2 ttl=250 time=89.8 ms
64 bytes from 66.18.65.124: icmp_seq=3 ttl=250 time=102 ms
64 bytes from 66.18.65.124: icmp_seq=4 ttl=250 time=89.4 ms
64 bytes from 66.18.65.124: icmp_seq=5 ttl=250 time=118 ms
Brolloks
Pinging www.sentech.co.za [66.18.65.124] with 32 bytes
Reply from 66.18.65.124: bytes=32 time=140ms TTL=249
Reply from 66.18.65.124: bytes=32 time=265ms TTL=249
Reply from 66.18.65.124: bytes=32 time=297ms TTL=249
Reply from 66.18.65.124: bytes=32 time=406ms TTL=249
Ping statistics for 66.18.65.124:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss)
Approximate round trip times in milli-seconds:
Minimum = 140ms, Maximum = 406ms, Average = 277ms
Also via smoothwall on Mintek
BAH!!
MyWireless 128, Tower: 82, Signal: 13%, SNL: 6, ber: 42%, node: 3
