Very possible... Merc GLA was throwing 4MATIC faults when the battery died. Those all cleared once it was charged up but the MIL stayed on. I had to clear it using my scannerMy car started doing this, coupled with all sorts of other weird symptoms (inc central locking refusing to lock, dashboard lights pulsing). After the car was towed in to a dealership they simply diagnosed it as a new battery being needed ... R1 200 later, perfectly working car again.
I've always had a sneaking suspicion the dealership lied and were actually covering up some other fault, because I've never seen a flat battery affect a car like that before, but then again the last time I had a flat battery it was on an old 1990s Toyota Conquest![]()
What you are describing is a flat battery - the fact that it's a new one means sweet blow all - we tended to replace 2 new batteries on new cars on the floor every month. Take it to Battery Centre and have it correctly diagnosed, as every person here is going to come up with a different possibility.
My guess is that the battery doesn't have enough oomph to start motor.
Thanks. Will test it in the morning. It is strange that it was working 100% yesterday though. Guess that's cars for you.
Remember when you jump start you probably don't get enough current down the jumper cables to actually crank your engine. Connect the cables and keep the donor car running at 2000rpm for a few minutes and then try starting.
I think it's more about the contact area of the crocodile clips. Generally it's tiny.Upgraded our jumper cables with some welding cables
Get battery charged
Get it tested at a battery place
