Pitbull
Verboten
- Apr 8, 2006
Edit: Voltage across battery with car idling is 14.6 or so. It seems like the alternator is working.
You need to have your voltage regulator replaced. 14 is fine for idling but it needs more the higher the engine revs as well as when items are switched on. I had a similar problem with my bakkie. Replaced the voltage regulator and my battery problems disappeared. I had to buy a battery about once a year before doing that. And if the bakkie didn't drive for 3 days the battery was flat. The charge isn't enough and it was also hovering at around 14 at idle before the change.
