Car not starting. Clicking noise.
Solarion
@OP. Have your starter motor checked out. The Solenoid could be burned out/needing new brushes.
Colin62
Checking the solenoid is easy - just short across the two thick leads with a spanner and the starter should turn. If it doesn't, it's not the solenoid. Don't use an expensive spanner, it might get damaged a bit.
SauRoNZA
My car started doing this, coupled with all sorts of other weird symptoms (inc central locking refusing to lock, dashboard lights pulsing). After the car was towed in to a dealership they simply diagnosed it as a new battery being needed ... R1 200 later, perfectly working car again.
I've always had a sneaking suspicion the dealership lied and were actually covering up some other fault, because I've never seen a flat battery affect a car like that before, but then again the last time I had a flat battery it was on an old 1990s Toyota Conquest :D
What car?
On a VW the one-touch up/down stops working on the electric windows when the battery starts going wonky. Seems to reset the setting when it runs low or something.
So I'm sure it will do similar things on other cars.
Colin62
With everything being run off electronics, you get all sorts of weird faults when the battery is dying and voltages drop. Usually they vanish when the battery is replaced.
AfricanTech
Much hilarity in this thread...
@OP, Tokai Battery Centre closest one I know of
Tokai (Cape Town)
268 Main Road
(021) 701 6509
-34.069538, 18.458083
Operating Hours
Monday - Friday: 08:30 - 17:00
Saturday: 08:30 - 12:00
^cut and paste from their website
bromster
UPDATE: Battery Centre put the battery under load until one of the cells started smoking. Dead. Buying a Willard replacement and will advise later.
Fazda
There was some seriously dodgy advice in this thread.
I know - that's why I originally posted.
Guys tend to know very little about a subject, but somehow feel that they have to give their advice, and 99% of the time they are wrong by a Country Mile!
bromster
Thanks for all the ideas guys. I was completely stumped. I couldn't understand how a battery could go from working 100% one day to not even trying the next. This, coupled with the fact that the battery voltage suggested that the battery was fully charged, is why I suspected something more sinister than a simple battery change.
But as soon as it was put under strain, it folded like a cheap hooker. And here I am, back on the road.
Did I mention how much myBB rocks?
thehuman
That is what bateries do
Wait till one explode underneath the seat you are sitting
Old type vw beatle
Segg
But why doesn't jump start work then?
Exactly my thoughts, if a jump worked with decent cables in the past, it should work again unless the battery is really really badly borked
SauRoNZA
Should work without battery even.
Unless OP is wiring it wrong, battery to battery.
