Cars Running on Timing Chains instead of Timing Belts
Neo_za
Out of curiosity which cars run on Timing Chains instead of timing belts ?
Drifter
This is wrong Ford: Fiesta pushrod 1.3, The 1.4 and 1.6 Fiesta uses a belt, the 2.0L Duratec in the ST150 is a chain.
Colin62
Huh? You quote the pushrod 1.3 and then say that a whole lot of other engines use belts?
Paul_S
It's not a very comprehensive list.
The Toyota RunX is also chain driven as well as the 2009+ 2.0 Kia Cerato/Forte.
Pitbull
Verboten
My mom's Suzuki Alto has a timing chain.
My 3.0 V6 bakkie has a belt, wife's 1.4i Figo has a belt. Dad's Mazda 3 has a chain. You can go on like this for days :D It depends on the model of the car. Even with Fords you get different engines using chains and different ones using belts.
konfab
Is the chain better or worst?
Chains have significantly lower maintenance requirements, they also do not break as easily. Something to consider if your car has an interference engine.
TJ99
All Mercedes Benz engines (that I know of) use chains.
Pitbull
Verboten
A chain will give you ample warning if it's busy going. The tensioner will start making noises. A belt on the other hand gives no warning what so ever and just breaks.
If your vehicle is serviced according to the service book you should have no issues with one or the other. Normally higher performance engines use the chain but it makes no difference.
mic_y
mini cooper s (R56) has a timing chain. Previous car (E36 328i) also had a chain.
Magnum
Toyota high performance engines loved their belts though. But they were all free revolving engines.
cpu.
Thanks guys.
phoenix99
A friend's Audi A4 recently snapped its timing chain. A lot more expensive to fix when it does go.
