CBI Astute Power Monitor / Switch -- Tasmotized!
3Gee
I see you using the Tuya app , there must be a bug in the CBI APP
Great to see works. I'll reset my Unit and set it up with the Tuya app
3Gee
Exactly the same error with the Tuya app. Has to be something on my network.
I'm using the AMPLIFI HD
The weird part is that Automations work perfectly, only Timer Schedules fail
Any suggestions out there
Weird part , CBI techie connected his Android phone and the timer schedules worked perfectly
Saba'a
Does Timer schedules work for other apps on your phone? Apple phone? Or Android phone?
Might be a setting on phone?
Clear CBI app caches just in case.
See below link for possible hint:
Vades
Well the Geyser is hooked up.
According to my electrician this isn’t a Circuit Breaker and shouldn’t be used as such.
Therefore it’s been linked to the existing geyser circuit breaker.
Thought he was talking kak until you pay special attention to the website and pamphlet and it’s only ever referred to as a Smart Controller.
I'm only seeing voltage on mine. No current, power or KWh.
Tinuva
The Magician
I can post a pic later but it's the same, just with the Astute fitted instead.
Lets try to rephrase it.
The geyser might be turned on, but if the water is at the correct temperature, the thermostat will turn it off, meaning it is not running.
Fill a bath with hot water to force the geyser to turn on and check again.
Vades
Thanks, did that last night and could see that apart was being drawn on the prepaid box, so geyser was running.
I'm thinking the issue could be related to the contactor, bottom right of the pic I posted.
For info, the geyser circuit breaker is situated 3 slots to the left of the contactor.
