Certified Gas Installation - who ? (gas hob)
ekske1
#1
Who to ask for doing a decent and certified including the cages for Pretoria. Then typically what gas bottle size should I take for a 60cm gas hob? I would think 2x 9kg might make the loading and refilling easier than say 2x 48kg. Finally rough cost estimate would be nice as I see price ranges from 2k to 7k.
spiff
#2
if your in cape town
I have 3 gas points - stove / geyser / heater - connected to 2 x 19kg bottles
Gaz{M}
#3
If you are only ever using a gas hob, I would take the 2 x 9kgs. They will last months and months and yes be easier to refill and transport. Only need the 48kg's for gas geysers and fireplaces.
#4
^ This. If you want to go the cage route, I would suggest rather do the 18kg cylinders. If you want to stick to the 9kg, sacrifice the cupboard next to the stove and put one gas bottle in there and the other in your garage as a spare. There are a number of installers in the pretoria area that can accommodate you
ekske1
#5
if your in cape town I have 3 gas points - stove / geyser / heater - connected to 2 x 19kg bottles
bit far from pretoria, but thank you :)
Will do. As it goes outside where its a pass through for complex upkeep.
CB40
#6
Not sure if they do Pretoria but West Rand Gas has a very good name. They are in Krugersdorp
Mista_Mobsta
#8
I am a bit late on the uptake but is having a 9kg gas bottle inside the home not a massive risk on your insurance profile and something you have to have certified and declared to your insurance company?
ekske1
#11
EcoGas completed the installation and I will go with them again:
  • Professional
  • Informative
  • Friendly
  • Thorough Checks
    • Complete leakage check after install
    • Hob checked
      • Nozzles
      • Normal lit
      • Manual lit
      • Safety cutoff of gas
    • Gas pressure
    • Every part working as it should
  • Cleanup
  • CoC issued
