Changing Led brightness level on IDS X series panel?
Snyper564
#4
No, you must tell others how.
Oh the installer came back and enabled keypad sleep mode. It's wasn't enabled initially. Once enabled the led light switches off after 30 seconds as that's the time that's selected. So there is no brightness setting but it does just switch off the display which works perfectly. Hope that helps!
Steamy Tom
#7
Ok so I actually did this today on my brother's panel, you actually do need to enable it despite changing the time out as above, it is location 252
So
* Installer code * 251* right arrow * ##
