I moved onto Afrihost with my MTN prepaid sim and there you get detailed billing of voice calls.
Noticed that missed call had a charge of between R0.02 and R0.16 and is showing a Call Forward to +27831650000
I queried this with Afrihost and the response was to disable call forwarding, which I never had activated.
I then went and ran all the USSD codes to disable any call forwarding and it still kept happening.
Logged another 2 calls with Afrihost and got the same response to run the USSD codes to disable call forwarding and I did it again yet it still happens.
