Cheapest power trollies and portable batteries for stage 6 load-shedding
grok
The best place by far is to keep an eye out for listings on BidOrBuy
I'm also using 8th Gen. Perfect price vs performance tier... older is a bit too old for certain fancy features and newer is still too expensive.
Thx.
The thing with the Gen8 is the hard drive slots, just keeps everything together neatly, but I've got 2 external drives connected via USB so not really that much of an advantage anymore lol.
  • Like
Reactions: Yuu
lexor
That thing looks cool.
I see it says:
Do you know what the solar input specs are voltage wise?
I can't seem to find the info on the site.
I bought the SPS1000 from Takealot exactly 3 years ago for R7450 .
Been working great the last 3 years.
The Deep Cycle batteries still working ok - but might go downhill fast with Stage 6 !
Will definitely replace the Deep Cycle with Lithium's !
The SPS 1000 Solar input is : 24V
The SPS 600 solar input is : 12 V
Specs here :
Hunted
They're simply too expensive for me to justify, but I won't lie, I have been tempted to get an Ecoflow as a worst-case backup to my backup or as something I can drop in the back of a bakkie with a solar panel or two and use it as a mobile power station for my electric dirtbike... that would be such an epic setup.
Which size one do you have?
Will I be correct to say that they don't work as a UPS tho?
Hunted
Anyone have some experience with this brand?
They sell a 1000w and 2000w version at Builders, but I can't find much with regards to specifications and so forth on it.
**EDIT**
I managed to get hold of Power 4 Less and this unit does not function as an UPS. So their advertising is misleading.
zolly
**EDIT**
I've messaged Power 4 Less about their larger inverter units on FB since their website is down.
3KW for 36k is pretty good in terms of pre-built units. Two issues I see on paper is:
  1. they don't charge quickly, but if you have enough buffer capacity this is a non-issue,
  2. and they don't list the unit's life cycles so there's no point in getting these if you're going to burn through their batteries with stage 4+ load shedding
PsyWulf
bwana
MyBroadband
Super Moderator
Even though we never exceed 3 x 2.5hr (though it is always closer to 2hr) through stage 8, I'm still glad we went the generator route. As long as I keep putting petrol in, it keeps doing its job.
Lupus
Work out your fuel costs per hour
bwana
MyBroadband
Super Moderator
Why?
I'm sure it's astronomical, or maybe it isn't, but I have power when I need it. I'm also covered when something breaks and takes a day, or more, to repair.
  • Like
Reactions: Yuu
Lupus
Why?
Cause you might've been able to replace it with solar and batteries :)
bwana
MyBroadband
Super Moderator
Realistically we only usually run the generator at night during load shedding so call that a couple of litres a day three times a week. Can I get solar and batteries for the R8000 a year I might spend on running the generator?
Lupus
Well considering the solar+batteries could also knock your electrical bill by 60% but I guess it's up to you :)
bwana
MyBroadband
Super Moderator
60%? Ok - so that's another R900 per month I could save. Add that to the generator costs and call it R20k per year. What does a solar installation run these days?
Sure, solar is on the cards but not today.
Lupus
so good you had to say it twice :p. Well yeah that 900 a month becomes 8000 a year :), next year it's R1100 a month, the next year it's R1500 a month saving.
Also you would run the generator less once the solar is installed and it can run R89k to the length of a piece of string, but it all depends on your usage.
bwana
MyBroadband
Super Moderator
So at R89k at R1500 a month is about 5 years. I'm going to defer that for a while. ATM we don't get load shedding because of the drought so the generator costs are minimal. I'm pretty happy with the status quo.
  • Like
Reactions: Yuu
