The Free Radical
- Apr 6, 2017
Safety concerns and irregularities at South African Airways Technical (SAAT) have affected both South African Airways (SAA) and Comair planes, operated by kulula and BA - with travellers warned of affected flight schedules and flight delays as a result.
SAA has issued a statement saying some of its flight will operate later than usual, with contingency measure being put in place as it has had to "recall some of its aircraft to undertake compliance verification in line with the South African Civil Aviation Authority (SACAA) requirements".
This follows the same audit inspection by the SACAA at SAA’s maintenance subsidiary, South African Airways Technical (SAAT) that has seen Comair needing to ground some of its planes.
SAA confirmed four domestic flight cancellations, saying it has combined flights and deploy bigger aircraft to accommodate affected passengers reduce the impact of the grounding.
Read more - https://www.traveller24.com/News/Flights/comair-grounding-what-travellers-need-to-know-20191022
