MisterBigglesworth
- Aug 15, 2006
Looking at getting an inverter. Did a bit of reading up here...and starting to get an idea of what they are and how they work etc, complete noob here BTW.
So I saw this 800W inverter here.
I would like to run a lamp, old Samsung 40" HD LCD and DSTV Explora on it as a minimum (maybe add an extra light or 2 if it can handle it). From what I read, I need to calculate the watts each item uses and then that should give an idea if this 800W inverter will suffice. Is that right? Read somewhere else about amps per hour (don't know what that means)
Other question - loadshedding is generally 2.5hrs max...will an 800W inverter running the above be enough to power those items for at least 2.5 hours?
Cheers
Input Voltage: DC 10-14V
Input Current: 0.3-25A
Self-Consumption: ≤ 1.5%
Output Voltage: AC 180 – 255V
Output Frequency: 50 – 60Hz
Cheers
