Concurrent Connection on usb Modem (adsl)
mh348
Anyknow if it's possible to run two accounts on a Usb Modem. I don't have a router and wanted to get a local account. I have a Mecer Usb ADSL modem. Here's a pic
DeFirence
Yep! It is possible!
Lo mh348
It is possible to run more then one account on the same line with a usb modem, ive done it with one of the cheap telscum ones...
you will need to get raspppoe from www.raspppoe.com. its pretty easy to install just make sure you install the protocol onto your virtual bridge between your pc and your usb modem, not your ethernet connection.
read the installation instructions on the website and you should have it up at running in no time...
DeFirence
:eek: :eek:
mh348
Thanks, everything is sorted out, just hav to get a local account now.
