Praeses
- Oct 29, 2005
I want to connect two houses, 1km apart, via wifi.
House A has ADSL, which I want to use and "PPPoE" from House B. I also want to be able to access the computers from both houses as with a normal network.
House B is in an apartment complex on the first floor while House A is on ground-level. The only possible obstructions between them would be more 2-story complexes between them, but I guess a long antenna can solve it.
Other than the buildings and some trees, there shouldn't be any other obstructions.
I want to go with a 5GHz setup for decreased interference.
What equipment do I need? How much will it cost? Will it be secure enough?
