Contactless card vulnerability allows hackers to bypass PIN
ConfusedR
Bank covers those.
Ok.
So I have to accept that money can be stolen from my contact-less card which does not always require a PIN
I understand that a "normal" card can also be compromised but at least it always asks for a PIN
Kosmik
Ok.
Money can be stolen from any card, if it us not authenticated by pin, bank is liable to re-imburse.
PsyWulf
Crux of the matter
Between the vendor bank and payment processor somebody will be paying back the money UNLESS you gave your pin and card willingly
krycor
Crux of the matter
Depends on what’s the reason for it. Cost eventually goes to
Card Association,
Card Issuer(bank),
Card Acquirer,
Customer or
Merchant.
Someone ends up paying pending what the breach is and if processes followed. The bottom two are the easiest scape goats.. technical failure of emv usually ends up with one of the top two if card related, customized issue with issuer, acquiring not being followed right vs risk in the center but usually passed to bottom.
Swa
Swipe or online. Times have changed though which is so many more transactions require pins these days.
Those will be the only occasions (other than contactless) though swiping asks for a pin too and online you have the CVV as the pin.
Kosmik
You can still contest cvv that's why 3dsecure is finally gone global.
