Coolermaster Masterfan MF122R RGB (LED Ring Design) x4 + 3 way Splitter and Control Box
Xander8807
Clearwater Estates, Boksburg
Hey Guys
The fans are immaculate condition, no bearing noise at all, still balanced perfectly. All LEDs working 100%.
Item: CM Masterfan MF122R RGB (4 Fans), 3 Way Fan power splitter, Control box powered by Molex Connector.
Age: seems to be quite new, lets say under a year.
Price: On hold till month end
Payment Method Accepted: EFT, GEOPayment (FNB)
Warranty: 7 Days on me
Packaging: None, can wrap up if shipping is done
Condition: Immaculate and cleaned recently
Reason: Will not be using
Shipping: Risk and expense on you
Collection: Yes, meetup can be arranged as well depending on Travel distance
Link: CM Ring of Light
Bundle Specs:
PRODUCT NUMBER - R4-122R-20PC-R1
FAN PROFILE - RGB
FAN SPEED - 650-2000 RPM (PWM) ± 10%
FAN AIRFLOW - 49 CFM ± 10%
FAN AIR PRESSURE - 2.17 mmH2O
FAN NOISE LEVEL - 30 dBA
FAN DIMENSIONS (L X W X H) - 120 x 120 x 25 mm / 4.7 x 4.7 x 1 inch
FAN RATED CURRENT - 0.42A
FAN MTTF - 280,000 Hours
FAN L-10 LIFE - 40,000 Hours
FAN RATED VOLTAGE - 12VDC
FAN POWER CONNECTOR - 4-Pin (PWM)
EXTRAS - Molex Power Control Box (RGB), Fan Header Splitter (3 to 1), able to Sync with Board RGB Software.
Item: Raijintek 120mm PWM 4Pin (2 Fans)
Age: unknown
Price: R200
Link: Raijintek AIO Cooler Fans
Fans Specs:
Dimension [W×H×D] 120×120×25 mm
Speed 1000±200~2000±10% R.P.M.
Bearing Type Sleeve Bearing
Air Flow 38.889 ~ 78.0 CFM
Air Pressure 0.744 ~ 2.97 mm H2O
Rated Current 0.05 ~ 0.21 A
Power Consumption 0.60 ~ 2.52 W
Noise Level 20.6 ~ 36 dBA
Connector 4 pin
Q'ty 2 pcs
Pic of Fans: (Only using the pic as they are in my box at the time, will be removed and cleaned before selling, testing welcome or can make a Video if requested to show they are working)
