Spizz
Goat Botherer
- Jan 19, 2009
I think i can get to the bottom of this easily.
Everybody says 20 minutes and up, you are 2 minutes or less from startup / cold.
And everybody is fighting about what constitute a cold start.
By everything i read, these engines are warm, they are not running, but the oil in the engine is kept warm at 60 degrees, with oil cirulating. Is this correct? WIth this in mind i can see that it can be ramped up withing 2 minutes. The engine is warm, so no biggie.
But for argument sake, what if the circulating oil was switched off. The engine stand there, switched off, no oil circulating, so at 10 degrees. Surely from this point on it cannot be <2 minutes?
Depends on temperature, more like 5 to 10 minutes.
An engine, whether petrol, diesel, gas, rotary or what ever, it needs to be warm, oil circulating, otherwise you will break it. You do not start your Ferrari and rev the crap out of it first thing in the morning. However after it is nice and warm, you can stop at garage, get a pie and some rennies, when you get back in the car give it a few seconds to make sure oil is where it is suppose to be, and you can give it horns. this i gther is the same as your engines. Warmed up but switched off.
More or less. But circulating with warm water, not oil.
It seems that the people arguing are unaware of advances in technology and software than enable quick start solution to be just that. It's horses for courses. If the combustion engines are providing base load running on natural gas then the quick start point is moor. If running on heavy/light/olive oil, the fuel will be stored in tanks at a proper temperature, same with a peaker. For a quick start scenario they need a different way of doing things altogether and that is as explained.
