CPU building problems..
billz015
Alright, I put in a new motherboard. The motherboards better, contains a Celeron as compared to the Pentium 1 that was in it before.
I hook in everything I need, the HD, the DVD-rom, the GFX Card, the power supply, and the tower.
I start it up fully expecting it to work, but a error message comes up, "CPU Unworkable or Broken enter Soft Menu"
I assume that means set up, when I go into setup there's not much I can do because all the settings are correct from my view.
Now it does detect the DVD-rom, but it doesn't detect the second IDE or the HD I have in.
What's the problem?
Ryder_JHB
Sounds to me like the Celeron CPU is not supported by the motherboard. I recommend that you ascertain the model number of the board and check the manufacturers site for a Supported CPU List. You may find that a bios upgrade is necessary to support "newer" cpu's.
billz015
the Celeron came with the motherboard originally and I took it out because it was a bit more firepower than I needed for the CPU, it did work perfect with the CPU beforehand.
How do I find the type of celeron?(the motherboard came in a computer that was bought in 99/00 and it was recently given to me because the owner decided to upgrade)
kongwane
dude u cant just buy a nu celeron processor and stick it in a 6 year old board and expect it to work just becose the previous one was also a celeron, U need to get a new board
spiderz
right socket alone does'nt always help.
I recently thru out an old board due to a fact that it could not pick up my newly aquired P4-2.8Ghz cpu. On the old board it only ran at 1.6Ghz.
Anyways, busy getting toghether a new gaming machine.
