Defy Automaid 238 drum leaking as it fills
craigba
Hey everyone,
I'm hoping that someone can assist (duh). We have an old (+- 10 years) Defy Automaid 238 from a mate of ours. Worked perfectly, recently it's been leaking. I can't find any decent tutorials etc for this model and can't find the filter / the pump or anything like that.
I have opened it up (back and top), turned it on its side, on its back etc and still can't find what's causing the problem. I do know that as the drum fills it is leaking...
Does anyone know where I can find something to help me track this down (tutorial wise), or failing that, someone that can fix this / look at it at a reasonable cost (I'm in Edenvale)...
Craig
WaxLyrical
Check for hairline cracks on the drum or pump seals need replacing.
Check for breaks on pipe as well
