Heksmeester
- Feb 28, 2011
Hello All,
I recently bought a trolley inverter with a 100AH lead-acid battery. When I came home, load shedding hit and I immediately put the inverter to use. It was only a few hours later that I watched a video from the manufacturer where they explained that the battery needs to be fully charged for 6-8 hours before the first use.
This piece of info was nowhere to be found in the instruction manual.
Today, the battery was fully charged and load shedding struck again. When "Backup Mode" kicked in on the inverter, the battery bar immediately indicated 3/4 bars as available capacity.
Did I damage the battery when I failed to fully charge it before first use?
Below is a link to the actual product:
https://www.takealot.com/lalela-hom...ley-ups-1-2kva-750w-high-quality/PLID90115597
Thanks in advance!
Thanks in advance!
