Does South Africa have a water crisis or simply a water problem?
Supervan II
These days, with load shedding, I'd consider adding a pressure tank into the mix.
Yeah, that's no biggie either. The 0.75kw pump is bit of an overkill for my needs, so might opt for a 0.37kw one and run that off an inverter (which I have just recently acquired).
BUT: Will be going totally off-grid (solar) in the very near future
Supervan II
What do you mean exactly?
One used to get kitchen/bathroom outlets that were exposed just above the drain, like this:
Vorastra
Ja, I have that. But it's just for the kitchen. My house is from the 30s.
We also have manholes.
But what do you mean by plumbed directly in?
That the municipal sewer connection is inside the property?
For example, we have a main underground pipe that the house is connected to, which then runs down to the municipal pipe under the road. Our connection stops at the boundary wall.
Isn't that how all houses are?
So once something goes down the drain, okes have no direct way of interacting with the pipe? Besides digging a hole of course.
Supervan II
Excepting for the traps inside, all water is drained directly into the sewer system. There are inspection/rodding and mini man-holes, obviously, but that's it.
Geoff.D
We haven't built any dams in years yet most of them are full. Its not a water problem.
Instead of pointing fingers at consumers lets first start with the average 37% of water supply being wasted across the country due to leaking and unmaintained water infrastructure.
Some municipalities lose well over 50% of the water they are allocated.
Then once that has been sorted out (in 50 or 100 years time) we can start focusing on the consumer behaviour. Even if consumers reduce their consumption to zero it won't fix the supply side water wastage issues.
And both of these are The useless ANC-led government's fault! The dams that were planned before 1994 had a dual purpose: One was for storage and the other was for flood control. Now we suffer because of both! Just imagine if all that water that rushed down the Vaal/Orange rivers could have been collected in the two dams that were supposed to be built along the lower orange!
Geoff.D
So much for global warming..
There is no global warming, beyond a known amount of about 1/10th of a degree per decade. The entire GW fallacy is based on a misinterpretation of the data available.
Geoff.D
Think how much water you use on a daily basis then work out how much of that really needs to be potable. It's really not much of a challenge.
This! It is crazy that we purify water only to throw it all away again except for that little bit that is actually consumed.
Geoff.D
Which brings one into a different topic - are we replumbing our houses to seperate rain/ground/grey water from potable taps?
It is a simple matter of educating people as to which tap to use for potable water. We already filter ALL our drinking and cooking water - why not just add one more stage/process to purify that water?
rvZA
South Africa is in a crisis in any way you look at it under the ANC. An electricity crisis, water crisis, food crisis, public service crisis including hospitals, traffic authorities, policing, justice and more, unemployment crisis, racism crisis. Things are about to get a lot worse in coming years.
Supervan II
RO system under the sink/counter-top RO system?
