E220 Edge Only
Jabba
Hi,
I have a E220 modem that initially was working fine with the 32K Sim cards, with the 32K I was getting just over 1M download speeds, however after I brought a 64K sim card the modem would not connect via the new sim to anything, GPRS/EDGE/3G or HSDPA. I then called MTN 1555 and they suggested I download the latest drivers from their website which I did and yes the new software works fine, however I can now only connect to EDGE, and only if I have select 3G preferred, if I select 3G only it does nothing, if I reselect 3G preferred then I see all three Networks but only for GPRS/EDGE, is there a setting somewhere on the software that I can change to allow me to connected to HSDPA
