Early Mate 30 Pro specs - 6.7-inch screen, Kirin 985, 55W charging
Currantly
Welcome to the first early look at the Huawei Mate 30 Pro. We emphasize the word early and suggest you take these specs with a healthy dose of skepticism.
According to claimed insider sources the Huawei Mate 30 Pro will boast a number of improvements over the Mate 20 Pro and the P30 Pro. Starting with the screen, the Mate 30 Pro will use a BOE-made 6.71-inch AMOLED with a built-in fingerprint scanner.
On the inside the Mate 30 Pro will use a 7nm Kirin 985 SoC with the Balong 5000 5G modem (though there will likely be a 4G variant of the Mate 30 Pro as well).
The cameras on the rear will be four and it's expected that there will be some variation of the current ultra-wide, regular, telephoto and 3D ToF setup. There's no definitive word on whether the zoom camera will be a periscope or not.
Linky
