EDGE is similar to 3G?
Dolby
I don't quite understand the mobile broadband offerings, so forgive me if this is silly question.
Is MTN EDGE the same as Vodacom 3G?
Would I be right in saying that it is similar to ADSL, albeit with the 100MB cap - for just R100 per month?
Dolby
Sorry arf9999 ....
I'm not that technical, so it looks Greek to me (EDGE, GPRS, 200mhz ...). Basically, it's not internet on the desktop? I understood it as internet on a home PC via a PCMCIA card, with low rates (the MTN pricing on the home page). They say ....
MTN's new packages include:
* Basic: this is a "pay as you go" solution and includes no bundled megabytes. There is no monthly subscription and data access costs R2/MB.
* 10 MB bundle: this costs R10/month and includes 10 MB of access, which works out to R1/MB. The out-of-bundle rate is R2/MB.
* 100 MB bundle: again, this works out to R1/MB at a monthly charge of R100. The out-of-bundle rate is R1,50.
* MTN 1 GB: this is the top-end offering and costs R499/month for an effective in-bundle rate of 49c/MB. The out-of-bundle tariff is R1,25/MB
If I'm wrong, what would be the the best/CHEAPEST always on Internet to have? Basically, I don't care about speed because I mainly chat and send text emails. I reckon I'd use less than 200meg per month.
arf9999
MyBroadband Member
EDGE is a GSM cellphone technology. Currently it is not as fast as ADSL or 3G or IBurst. It does require that you have a EDGE compliant card or phone and are in coverage area (according to MTN about 20% of their total network).
In addition, you obviously need an MTN connection. As I understand it (but I may be incorrect, I haven't checked with MTN) these offerings are available to MTN contract customers, so you will need to buy a SIM card, and pay a monthly contract fee.
If your requirement is for a fixed installation (i.e. Desktop PC at home) I would probably suggest that HomeDSL192 may be a better and overall slightly cheaper solution, especially with a 2GB ISP account.
If you need to have internet access while mobile (e.g with a notebook PC), then EDGE is a good solution for low to medium amounts of data...i.e 100-500MB. While the speeds are not the same as 3G, for lower requirements it should perform adequately.
TheCynick
Hi Dolby,
The first thing you need to remember is that you have to have a device that supports one of the data carriers on the network, be it GPRS or EDGE or 3G. This will either be a cellphone (hopefully your existing one), which can be used like a modem, or a dedicated datacard, which would need to be purchased as an extra.
Obviously you also need either a contract or a prepaid SIM. With both MTN and Vodcom you don't get the benefit of the bundles on prepaid - the bundles can only be added on to a contract.
Once you have it all set up correctly, it is basically a dial-up networking connection on your PC.
Also remember that with the bundles, once you hit your limit (say 100 MB) you are not capped/kicked-off - you are charged the out-of-bundle rate. So it is important to keep track of your usage by using one of the monitor programs that has been discussed on many threads around here...
I personally like the look of this as a method for home internet access - I would only use it ever now and then to check mail, book movie tickets and settle arguments with Google :) so my usage would be quite low as well
HTH
Dolby
Hi ... Thanks for ther advice.
If this is similar to dial up, then the only benefit would be the speed - right? What speed would one get, roughly?
ajax
3G -> up to 384 kbps
EDGE -> with an EDGE data card or phone that supports 4 timeslots for download up to 236 kbps
GPRS -> with a GPRS card or phone that supports 4 timeslots for download up to 80 kbps.
My experience with GPRS is that it usually averages around 40-45 kbps.
Don't know about averages on EDGE or 3G, can anyone comment?
Dolby
hmmm ..... so it's actually really good for low internet usage! My main usage would be mIRC. Below are my calculations ... do they seem right?
I was told mIRC uploads/downloads take roughly 2MB a night, as it is only text (roughly 3 hours a night). Therefore it'd take 50 days to use a the full 100MB (150 hours) - at only R100???
I know pricing is only going to be released later, but I'm working on this ...
diabolus
Depends on what you do on Mirc as you can download -files- as well. Just chatting i'd say yes, you can probably go on 2MB a night depending on how many channels you use and so on. The same applies to messengers [MSN/AOL/ICQ] which is also pretty low on data usage (again chatting only, audio/video chat is a different story).
Also games like WoW/Everquest [mmorpgs] use similar low amounts [i play AO and it's about 1.5MB per hour]. This is not the case for Counterstrike/UT though.
So far browsing is pretty 'expensive' for me compared to chatting, especially since websites are easily 200kb "per page" these days [So one visit to say my Vodacom Data usage page can easily be 1MB+ after i'm done, and that's in 5 minutes]. Can't really turn off all pics since it's usually part of the interface.
But to answer the question, if you're only going to chat [or use purely text based services like messengers] then yes R100 - 100MB should do just fine. I could easily do it playing an mmorpg and mudding [mudding = text based mmorpg].
Dolby
Wow :) This is actually pretty decent then!! I'll take this connection the 2nd in comes out! Any idea how much the PCMCIA card costs? I guess it'll be availbable at the end of the omnth only :(
Basically, my IRCing costs me roughly R400 a month (on a prepaid Telkom line with no Infinite Call). I'll easily be able to get by now on a R100pm ... since I don't need speed nor large data downloads/web browsing. I'll get a data monitor just to make sure it is only 2MB a month though.
Why does an MMS cost so much then ... ? I thought it was also charged for amount of data sent, and I bet sending a 100MB file (in theory) would cost more than R100 ...
ajax
Vodacom's card is going for around R2000. MTN's one will probably be priced similarly, although I would welcome (downwards) correction in this regard!
Dolby, do you have a GPRS or EDGE phone? Use that in the meantime (if you are really in a hurry buy a Vodacom sim for R10 or something and use it out-of-bundle), it is a great way to test before spending money on a card.
But if you can't use infrared or Bluetooth to connect your phone to your pc, you will need a cable, and they cost a couple of hundred usually.
Dolby
Hey ajax ...
You've actually brought up another potential problem, I think. If one does use the cellphone over Bluetooth, surely they'd be limited to that connection ... ? I've heard EDGE is roughly 104kbits (13kb/sec). Bluetooth AFAIK is a little slower, and Infrared is alot slower!
If this is the case, I guess it would be best to wait for a PCMCIA card?
arf9999
MyBroadband Member
Bluetooth is usually around 500kbps/800kbps depending on the device and the interference. Maximum is 1Mbps. Should be more than sufficient. But generally i have found that setting up bluetooth with a computer and cellphone is just a pain in the @ss. If you can get a cable, it is simpler and easier (or get a card..).
diabolus
Wow This is actually pretty decent then!! I'll take this connection the 2nd in comes out! Any idea how much the PCMCIA card costs? I guess it'll be availbable at the end of the omnth only
Just a few things to think of though. You need a contract to get that R100 - 100MB bundle as far as i know [the same applies at vodacom, you can't buy bundles on prepaid]. I'm assuming you already have a contract at MTN. Either way, you can get the 3G pcmcia card for free [instead of a phone] on most contracts at Vodacom , i assume MTN will have similar options [so if you can upgrade etc etc, probably worth a look].
So if you don't have a contract, or will only use it for internet, you have to add that cost to it as well [probably another R125 ], unless you get the pcmcia card for free with it [then that'll generally cover the contract cost].
ScrnScrm
Hi - I get about 160Kbits/s ROUGHLY on download. Depends on the time of day. Slowest i have seen is about 100Kbits/s, and i have seen it burst upto about 220Kbits/s for short periods (like a minute or so).
in short, its perfectly useable :)
bHOLDher
There is a place in Boksburg that sells certain data cables for much cheaper. I believe other cell shops would not like them to sell to the public, they are actually distributors or whatever. Check out their price list at www.activecellular.co.za
Le^stat
I use Edge....ave d/l speed is 13-15kb/sec.Dont waist your time...get adsl
