A lithium can charge at upto 1c
Which lead acid charger can charge a lithium in an hour?
Lead acid charger are designed to do like 0.2c to not boil batteries
And desulfation cycles won't lift the cell voltage the lithium would just soak up that charge
And if you can find a cheap device that can push more amps than the bms allows
It disconnects the cells so worst case it just doesn't 't charge
If you had crappy lithium with crappy bms sure you might have problems but like i said , before it makes better sense to do one device change than a battery change every 18mnths, any seller keeping people in the lead acid cycle should be avoided
We get a ton of calls from dissatisfied customers who followed advice such as yours - who find that the device they are using does not charge their LiFePO4 batteries in the way that such internet experts advised.
You assume constantly regarding damage to the battery. It is far more complex than damage to the battery. Manufacturers have invested millions to ensure that specific lifepo4 chargers employ the correct current limiting criteria as a first line of defense, as opposed to relying solely on the BMS to protect the battery.
talking about cheap devices and cheap batteries - the topic of this thread, you are going to be constrained with cheap and basic BMS - which often will employ only over-charge, deep-discharge, and temperature controls . There are very few lead acid chargers that will safely and effectively charge a Lifepo4 battery to the proper charge.
How about automatic equalization modes constantly hitting the lifepo4 battery with 15v, either the BMS doesn't protect it properly given the short bursts, causing damage to the cells, or it completely disconnects requiring jump starts. Why do manufacturers go to such lengths to ensure that the LifePO4 charger limits voltage to 14.6V - while lead acid chargers without modification will routinely charge above this voltage forcing the BMS protection which if poor doesn't respond that quickly or simply switches off.
Then start looking at absorption and bulk charging stages with LifePO4 ideally functioning with short absorptions stages. The process is completely different to lead acid chargers which chargin in bulk stage to 80% with increasing voltages at full current, and then moving to absorption phases with decreasing current - running the risk of never fully charging your battery.
The lead acid charger most likely won't restart bulk charging untll your LifEpo4 battery is virtually depleted- this means that with the different discharge curves, you basically have to use all of the LifePO4 battery capacity before your charger decides to start recharging your battery.
So basically there are quite a few caveats that need to be checked bfore you can use a lead acid charger safely and efficiently on a lifepo4 battery - above are just a very few .
Frankly your advise is very poor.
Make sure that your lead acid charger is compatible with LifePO4 batteries, by checking the 5 or 6 different criteria , which often on cheap devices such as ups, alarm systems etc cannot be ascertained - or get a LifePO4 charger, or get a SLA battery that is double the capacity of your expected load.
