Electric car charging challenges to consider if you want to use home solar and batteries
If you time your charging periods to shorter periods during the day, there is no need to spend large sums on a 10kW charging unit
A fellow in Tokai has run a Nissan Leaf since 2019 and manages fine on his 10-panel solar system. He finds that 30 to 45-minute charging cycles every day or longer on Sundays is more than adequate to keep the battery in the 90% - 95% SOC
You can always set the car to charge slower. No need to push it to 100% every day. That way you can charge with any excess solar power you may have. I’m sure you can use home assistant to set up an automation. These charging stations can all have their charging power they provide to a car controlled externally by Ethernet/Wi-Fi.
