Jongi said:
Could you guide me step by step how you went about configuring iBurst. Even if it's through the CLI.
Assumptions:
eth0 connects to iBurst UTD
The simplest way to manage this is:
1 - Get a terminal
2 - su
3 - adsl-setup
- Follow the prompts
4 - Done
If you don't want to use adsl-setup or you'd like to experiment more...
Edit /etc/ppp/ppap-secrets
"username@wbs.co.za" * "password"
Edit/Create /etc/sysconfig/network-scripts/ifcfg-ppp0
USERCTL=yes
BOOTPROTO=dialup
NAME=DSLppp0
DEVICE=ppp0
TYPE=xDSL
ONBOOT=yes
PIDFILE=/var/run/pppoe-adsl.pid
PING=.
PPPOE_TIMEOUT=80
LCP_FAILURE=3
LCP_INTERVAL=20
CLAMPMSS=1352
CONNECT_POLL=6
CONNECT_TIMEOUT=60
DEFROUTE=yes
SYNCHRONOUS=no
ETH=eth0
PROVIDER=DSLppp0
USER=username@wbs.co.za
PEERDNS=yes
DEMAND=no
Remember to set the "ETH" line to the ethernet interface your UTD is connected on.
Set the USER to
username@wbs.co.za
You need to get a firewall setup and also remember that if you are going to use this as a gateway, enable ip forwarding and get nat going.
Hope this helps...
