Fibre Question!!! Someone please help me i am new to fibre
TautLawyer77303
Good Day,
I would just like to know if someone can assist in this matter.
Okey here we go...
We are in the process of moving to Pretoria and where we are moving to there is Fibre there and everything has been installed there at that house by the previous owners and the connection to the fibre box(PS:the box is grey with a yellow label on it, it is outside the house) there is also the connection inside the house(Where you plug in the cable from the box to the router it looks like a plug). So all i want to know is do i need to get a modem or does my ISP(Telkom) provide one for me or can i get a Router/Modem Combo(I think it is the one that has a ADSL and WAN port with Ethernet ports). Any info is welcome and please help And can someone please explain this to me i am new to this Fibre.
RocketNet-Rep
Company Rep
Good Day,
Okey here we go...
Hi there
Your ISP should provide you with the router you need, are you moving into an Openserve Fibre Area?
TautLawyer77303
I am not sure if i remember correctly the label said Afrihost but i am not sure i just remember that the label was yellow
TautLawyer77303
How do i send you the pm. Because i know the label was Yellow and the box grey but i dont know what was the name on it
TautLawyer77303
The area is Rietvalleirand Pretoria. I did check at one point and it said that the area "Rietvalleirand" supports fibre but i am not sure if it supports telkoms
