Fill Jet Ink cartridge refill kit
zizo911
Does anyone perhaps know where i can get the Fill Jet set from Glomail. No shop has it and Glomail also doesnt seem to stock it...
Or perhaps can anyone suggest a similar product which will do the same job.
Thank You
Zizo911
sal12344
I have seen them at Game stores, but I would rather use compatibles instead of this. These DIY refill kits usually end with damaged printer heads.
