FTP Problem
ambience
Hi all,
I'm having a rather strange FTP problem that I hope somebody can shed some light on.
The FTP server in question is : www.bubblers.co.za
I have the 128k package, and m currently connected to 66 Hyde Park, around 27% strength, 4 lights, no problems at all (apart from speed ;)
I use PPPoE with a Linux Smoothwall implementation, all patches applied. My machine is Windows XP. I have the same problem whether I use USB on my machine directly or not. I am using passive mode when using the firewall.
Ping to www.bubblers.co.za :
Pinging view.ledge.co.za [196.25.69.175] with 32 bytes of data:
Reply from 196.25.69.175: bytes=32 time=268ms TTL=245
Reply from 196.25.69.175: bytes=32 time=145ms TTL=245
Reply from 196.25.69.175: bytes=32 time=303ms TTL=245
Request timed out.
Ping statistics for 196.25.69.175:
Packets: Sent = 4, Received = 3, Lost = 1 (25% loss),
Approximate round trip times in milli-seconds:
Minimum = 145ms, Maximum = 303ms, Average = 238ms
Tracert www.bubblers.co.za :
Tracing route to view.ledge.co.za [196.25.69.175] over a maximum of 30 hops:
1 1 ms <1 ms <1 ms smoothwall [192.168.0.1]
2 246 ms 216 ms 302 ms 66.18.87.50
3 223 ms 237 ms 119 ms 66.18.65.105
4 201 ms 1258 ms 197 ms gige-0-0-102.rtr-core5-stp.infosat.net [66.18.65.106]
5 223 ms 202 ms 439 ms gige-0-0-6.rtr-core4-stp.infosat.net [66.18.67.254]
6 209 ms 344 ms 195 ms gige-0-0-21.rtr-bdr1-rbn.infosat.net [66.18.65.209]
7 1146 ms 279 ms 267 ms 168.209.18.61
8 213 ms 242 ms 217 ms 196.26.0.251
9 431 ms 420 ms 320 ms 196.25.5.29
10 206 ms 252 ms 240 ms rndf-ip-er-1-fe-8-1-0.telkom-ipnet.co.za [196.43.11.210]
11 225 ms 238 ms 221 ms intekom-34meg-gw.gt.saix.net [196.25.245.50]
12 455 ms 375 ms 226 ms rock.ledge.co.za [196.25.69.175] Trace complete.
Ftp to www.bubblers.co.za
Connected to view.ledge.co.za.
Connection closed by remote host.
Ftp to www.sybaritic.co.za
Connected to www.sybaritic.co.za. 220 FTP server Version wu-2.6.1(1) User (www.sybaritic.co.za:(none)):
All other FTP sites I use work perfectly.. :( I have asked a friend to try FTP from a corporate network through MTN and he has no problems getting connected - I just cannot connect through MW to this specific server. Any suggestions?
ambience
Yep ;) Use passive mode via ftp apps when using firewall / ppoe, but also tried dos ftp when connected directly via USB. Same results; all work except that one damn site.
Anyone else on MW that can connect to that server and get creds?
ambience
Resolved.. turns out the host was firewalling 66.* addresses due to hacking attempts... [:p]
