Galaxy S4 Boot Loop - No Recovery Mode - Odin Mode Flashing fails - HELP
MrG
Hi guys,
Not sure what happened to the phone. Turned it off and when it came back on.... boot loop. Occasionally makes OS but only stays for like 3 seconds.
Recovery mode for half a second flashes an Android that is lying down and it restarts.
Safe Mode also causes a reboot.
Flashing results in this:
Hectic
How old is the battery? Maybe try with charger plugged in?
Beachless
Had the same issue on my s4 ended up being the power button.
After I disassembled it and clipped off the power button with a small sidecutter and used a alternative way to power it on it worked fine for another 6 months till I replaced it.
MrG
I also had the power button issue, which is resolved, like you by using alternative methods.
When I put the battery in, it does not auto boot and when in odin mode it does not reboot, so the power button is not getting stuck in an on state.
This is different from that.
marioat1
Hi guys,
Did you come right?
Is your s4 a 9505 or 9500?
raeesdawood
Hi guys,
Hey still need help?
Your phone is soft bricked options
Download samsung drivers
Use a different usb cable
Different usb port
Find out what model u have gt i9050 or whatever it is
Download the official firmware off sammobile
Use that tar file in ap of odin
Put phone into download mode it should flash blue if it connects
Flash the official firmware
Hope u came right i had this issue with my s3
