Gas cylinder level monitoring
bwana
MyBroadband
Super Moderator
When the gas runs out it's empty - thats a good indication it's time to get a replacement.
MickeyD
RIP
That's why I have 2x 48 cylinders... When the one is empty I flick a switch and know that I have a few months to replace the empty one.
But the SO did insist on the gauge on the regulators... Overkill...
Sinbad
I have the switch setup as well. Just need to optimize cash flow atm.
BigAl-sa
A gauge on an lp gas cylinder doesn't help too much as it can only measure the pressure of the gas, which is constant while there is liquid in the cylinder. When there is no more liquid, the gas certainly won't last too much longer.
As mentioned earlier weight is the way to go.
jansdejager
bathroom scale will measure up to 300kg probably so just get a cheap and sturdy one and keep it underneath? they usually even have tare but only industrial ones let you set beforehand. anything else will eventually perish so :shrug:
richjdavies
Spot on advice. There's nothing else to say! All the fancy gadgets in the world won't do it - you care about HOW MUCH gas is left... in Kilograms... that's all you should bother measuring.
Stick a scale under it and you're done for ever. Even get one of those luggage scales if you want. You don't need to lift the whole lot at once, just get it under there and then work out the numbers. Easy peasy.
AntiGanda
Banned
Our local fishery has gas cylinders which they keep shaking. Why do they do that?
CamiKaze
Take warm water and our it down the side of your cylinder. Feel with the palm of your hand on the area that you poured warm water on and move your hand down until it gets very cold. This will tell you how much gas you have left.
jansdejager
Alternatively wait until somebody tries to snatch your canister because they only seem to do that when it's almost empty and light enough to carry.
HavocXphere
The same works with diesel tanks in the mornings too...except you don't need water. You can literally feel the temp diff.
Shellyb1
The cylinders have a small bearing in them and when completely empty, the bearing rolls around at the bottom.
Means it's completely empty when you can hear the bearing.
AntiGanda
Banned
I imagined it was like shaking a deodorant can to get the most out of it.
BigAl-sa
That only works while you are actually using the cylinder. See my earlier posts.
