Generator running costs for low, medium, and higher usage scenarios
bwana
MyBroadband
Super Moderator
What is the socially acceptable time to crank a generator? Our power went down last night and I'm thinking the refrigerator could use a little power.
RonSwanson
It depends where you live. In most residential suburbs, 06H00 to 22H00. In PE, it's rural already so anytime.
iu
iu
iu
  • Haha
Reactions: rh1
Lupus
The fridge if not touched should hold a few hours.
rh1
Ok, so I have this bad boy for days that seem too long without power. The baffle box works like a charm and is sporting 1 radiator fan which I had to get an AC-DC power supply in order for it to work but none the less it works. Sounds like a car idling especially at night or early morning you just don't hear it much. The box was R4000-5000 and the insulation 2 squares I think was 2/2m which was around R1500. Yea the one door broke off cause the guy that built the box used crappy hinges.
The generator uses Lique Moly 10W40 with a pretty expensive sparky. The fuel consumption on a full tank is 9-12 hours depending on the load. It runs the entire house.
The inverters I run with is the Ellies modified sine wave 1440W battery kit this is the big one, runs my entire wireless system and routers for about 9 hours, perfect for me cause I used to do night owl shifts where I needed to run the genny at 2-4 shifts and that was k@k.
The 2nd inverter is a simulated sine wave 3KVA which supplies power to my PC only currently it used to do the network but I have too many things on that side. Kstar is the brand and the software is none existent.
I had a 900W gen but the problem I ran into was when the moister in the air was at a certain point in Pretoria it would battle its ass to keep with a 300W load. Sold it to someone for the same price as normal since it still had a year warranty registered.
Sound material: type and where did you buy?
rh1
I waited until 7:50.
I think everyone was waiting for someone to kick it off because soon after that there were plenty of others starting up. :)
I have the same issue with the petrol lawnmower, 6am is perfect, not yet hot, but I have nice neighbours, so I cut my grass later in the hotter weather.
HartsockZA
  • Like
Reactions: rh1
joshuatree
Anyone have experience with this inverter generator: MAC AFRIC 1.8kW Inverter Generator
R7250.
Would Adendorff's range of Mac Afric generators be better than the Ryobi brand?
rh1
R7250.
I only have the normal mac afric generator. But if I could afford an inverter generator, I would not hesitate to take a chance their brand.
Mike Angelo
They also have excellent after sales service.
AlphaJohn
R7250.
I can only speak of Adendorff as I worked with them directly.
They deliver on site, and have great service have had no issues with them or their equipment to date.
