In terms of instant power, cost and flexibility, nothing beats a genny, however they need maintenance and are smelly and noisy. This is where the Synapse solution shines, provided that you get a chance to charge it, stage 8 is nasty. Ideally you want both
, the genny gives you the ability the generate electricity anywhere, anytime which the Synapse does not.
I am not familiar with the brand you have pointed to, but others in the TradePower range look suspiciously like white-labelled
Gentech products, which are good (for occasional loadshedding use).
If not in use, it's best to drain (and then use) the fuel, because it evaporates, and residues will gum up it's internals. Also never keep fuel longer than 6 months, rotate and use it, store and fill with fresh fuel only.
