If i replaced my kwikot geyser element and thermostat and it's still not heating the water can i assume that the breaker on the board is faulty?
I'm getting a multi meter tomorrow, across which terminals should i measure on the thermostat to check if there's 220 volts?
We do only turn the geyser on once a day only so it will have some wear and tear.
The wiring is very old and no isolator switch in the attic that complicates things, it should be directly wired to the breaker on the board.
