Giant Talon 29er mountain bike, XL frame size, 1x10 gears [S]
Rouxenator
Dank meme lord
Item name (be very descriptive): The bike was completely rebuilt and fully serviced (shock included) 70km ago. I just rode Die Burger with it then washed it. New frame and new XT rear derailleur, the rest of the parts were all good. Neat 1x10 bike with the wide ratio Sunrace cassette and plenty of life left on the Crossmark tyres.
Age and condition: Less than a year old, perfect condition.
Do you include packaging: No
Warranty: No
Reason for selling: Bought an older 2014 MTB that I ride more, would have loved to keep both but I need the cash.
Price: R13000 (they go for R24000+ new)
Negotiable: Yes
Shipping or collection: Collect
KEY SPECS
Model Year: 2016
Frame size: X Large
Wheel Size: 29"
COMPONENTS
Frame: Giant Talon 2016 XL
Fork: Rock Shox Recon 100mm MLO QR
Wheels: Giant S-XC2 tubeless with Maxxis Crossmark LUST
Rear derailleur: Shimano XT 10 speed (new)
Shifters: Shimano Deore (rear only)
Brakes: Shimano Deore M615 Hydraulic 160mm front and rear
Crankset: Kitted 32T Narrow Wide Wonder ring
Cassette: Sunrace 10 speed 11t-42t
Seatpost: Giant Connect (stock)
Saddle: Fi'zi k (upgraded after pics)
Stem: Giant Connect (stock)
Handlebars: Giant Connect (stock)
Pedals: Ryder Dual Platform (flat and SPD)
Ppretor
Just curious
Not an MTB expert, but what are the advantages/benefits of the single front sprocket?
Warranty: No
Price: R15000 (they got for R24000+ new)
Negotiable: Yes
KEY SPECS
Model Year: 2016
Frame size: X Large
Wheel Size: 29"
COMPONENTS
Pedals: Giant flat pedals
Rouxenator
Dank meme lord
Lower maintenance and lower weight. Your chain tends to last longer as the front derailleur is not as gentle as those found at the rear. You disadvantages are you have a narrower set of gear ratios available, however with this bike I have fitted a very wide ratio 11t-42t cassette at the back so the lowest gear ratio is on par with a typical 3x8 (24speed) MTB you find in most shops.
