Glass screen protectors for 6s and 6s Plus
balrog
Hi Guys!
Can anybody confirm that they are using glass screen protectors on the 6s and 6s+ that they are happy with?
Upgrading end of month, and thinking I need to protect those screens!
Googling indicated a lot of people are unhappy with these on the "s" models.
Was hoping somebody can indicate a brand that they are happy with, that one can source locally.
Thanks for any help :)
JStrike
I use one (Cant remember the brand. Got it from DigiCape) for my 6s, and it really is remarkable. It genuinely works.
And you get a free replacement after it breaks (And it will. But your screen doesn't)
Volkyrie
The problem with the glass screen protectors on the iPhone 6 / 6s is that the phone was designed with a curved glass edge which makes the swiping back gesture to go back in menus / safari easier - the protector kinda makes that 'benefit' obsolete.
Also, just remember, glass screen protectors are not as solid as the glass on the phone itself, so while the protector might break, it doesn't necessarily mean that the phones glass would have broken as well.
ahoudet
The curved edge doesn't stop you from swiping nicely, it still works fine. 3D Touch works too... I'm happy :)
