Gmail problems
kvi
Hi guys...
anyone else on gmail having problems ?
gmail is fine on adsl, but on my 3g card i can surf net no problem, talk on google talk no problem, but i cannot reply to any gmail mail. also cannot compose and send attachments. can recieve mail fine.
thought it was my beta firefox im using so tried IE but still same problem.
sometimes can reply to a mail but not always, especially if there is an attachment in it...
but gmail is fine on adsl so i know its not gmail themselves. 2 friends have also complained about their gmail on 3g today..
Syndyre
On Virgin at the moment and its working fine but my gmail was fine on Vodacom yesterday as well.
kvi
seems i can reply to text gmails but cant reply to messages with attachments
ic
MyBroadband
Super Moderator
wow yes...
whats the difference?
https content will not be cached by Vodacom's Proxy server(s), whereas http content will be cached...
kvi
so i wonder what changed at vodacom over the last couple of days?
vodacom3g
Vodacom Representative
Can someone write a short synopsis of what you saw (as a problem) and how the https version fixed it. Something I can pass straight to the Engineers to trace?
I don't have a Gmail account to test (awaiting flood of Gmail invites....).
web
is that a hint ?
kvi
sorry im no linux/windows TI gury :)
my thread posting was the best i can do....
you want gmail invite?
vodacom3g
Maybe ic can write us a short summary? Being the GMail evangelist and all....
An invite would be cool, if you don't mind. Then I can test with you guys.
ic
MyBroadband
Super Moderator
v3g_gmail_invite_count++; :D
My suggestion to use the https GMail url, was simply a guess as to a possible workaround :). I suspected that Vodacom's Proxy servers might be unintentionally caching & messing with the unencrypted GMail content when someone uses the normal http url.
Usually a Transparent Proxy server will not attempt to cache content from an https url simply bcos it is encrypted and is essentially meanlingless from a bandwith saving POV...
Vodacom should probably look at excluding http://mail.google.com/mail/ from being cached by its Proxy Server(s). GMail uses AJAX extensively and is very economical when it comes to data transfer usage.
Veroland
Well
Sometimes when you try to submit (i.e. sending) a mail it seems that the browser makes contact with the gmail site but does not return a response.
kvi
ok who is the lucky person that gets their invite chosen....... holding thumbs
eagle-slayor
not only gmail but yahoo also with problems, ive stated that in quite few threads but i am ignored, i do get help but the actual problem doesnt get solved...
rehd
Hi guys...
sorry for the late reply... go onto accounts on your outlook , edit the settings and under advanced tab where it says this server requires encryption connection, remove the tick box. seems it is not only VC that is having this problem
eagle-slayor
only problems i have is that i cannot reply to emails in the "standard" mode, while in basic html mode they go tru
