Going old skool
quintin1986
Hi guys, i've recently decided to go oldskool with pc's
I found an old pentium 2 pc
CPU: 466 MHz Celeron CPU with mmx support
RAM: 128 mb sdram at 133 MHz
HDD: 40 GB IDE hdd, but bumped it down to 30 GB, otherwise the pc won't detect it.
Grapchics: AGP Riva TNT 2 at 32 mb
SOUND: ISA ESS 1869
CD-ROM: Samsung CD writer
Other: Standard 1.44 mb stiffy drive
Actually had to buy the ram, and get it shipped from Capetown...
I'm currently running windows 98+ on the system.
I've also got another old pc which i let the kids play on.
Pentium D class 3 GHz dual core CPU
1 GB ddr 2 ram
I've installed windows xp on this machine.
BUT NOW, for this pc I'm looking for a 128 mb+ agp 8x graphics card
Does anyone know where i can buy one for a good price, or perhaps got one i can buy?
I'm also looking for more vintage PC'S
386, 486, Pentium 1
Or even old XT machines
If someone can help, or has got any input please reply?
I'm in the East Rand,,, Primrose.
Quintin
D3athD00r
SOUND: ISA ESS 1869
1 GB ddr 2 ram
386, 486, Pentium 1
Quintin
I might have an old agp card somewhere. If I find it you can have it for Nada.
ponder
Got a Asus, board says A9600/TD R1.00, sticker says A9600SE/TD/P128M/A
Was working when removed from PC, can test it if required. PM if interested.
Seriously
Why torture yourself like that?
It's fun. I had to rebuilt a DOS PC recently with networking which had to retain enough DOS memory and still be compatible for a program to start in a Win32 environment. Sigh. Was a reliving experience to go back to old DOS.
One thing I learned. DOS is not dead!
quintin1986
No, dos is not dead...
I'm running an mp3+ player in pure dos mode on the pentium 2 and also movies .avi .mp4 etc in pure dos mode even got a web browser.
sajunky
I am sure I will find some 128MB 168 pin stick. They don't work on all configurations, so I keep more, there is a chance it will work on your PC.
Recently thanks to some forumnies I upped my stuff, so will also have some old HP laptop Pentium M or Core Duo ready (missing power supply, battery and hardrive). I was keeping it for myself, never used, but tested, the motherboard is working 100%.
As for the AGP graphics card, recently received from lived666 two cards: ATI Rage 128 Pro with dual fans and GeForce2 MX. I have no use for it, it could be yours. Don't know it is AGP 4 or 8 though.
ODTech
Speaking of old. My first computer AMD K350 is also still running, leaking caps and all xD.
For future reference you do still get AT power supplies brand new.
GhostSixFour
Username approved by US Airforce
So, do you like paying too much for electricity? Go to newer tech, will reduce consumption. You'll also be able to achieve more with fewer machines.
Sonic2k
In any case, I also have an old machine. It runs my VPN.
It was bought in 2005 from Rectron, along with its processor. RAM has been upgraded, as I cannot get DDR2-533 anymore, so its running DDR2-800 modules. Cannot upgrade it past 4GByte since motherboard then gives POST error beeps.
It runs XP and several instances of Linux in VMWare player (usually just one at a time).
It is a very capable machine for what it is used for. And yes it runs an AGP card I bought in 2003.
As for power consumption, uses less than my current desktop PC.
garyc
Earlier this year had to do some work on really old software. This meant setting up a DOS system that would support the old compilers that it was developed for. Since then I have modified the code to be compatible with gcc under Linux.
It was an interesting experience while it lasted.
quintin1986
Hi guys, thanks for the replies.
Sorry I'm only replying now, but had a bit of a hectic day.
GhostSixFour, the old machine isn't my primary machine, i only got it to play around with.
My primary machine is an oldish server,
CPU: Intel xeon on LGA 775
RAM: 4.5 GB RAM
HDD: 1 TB
HDD: 500 GB
Graphics: GeForce 9300 GS
Sound: Cheap C-Media sound card.
OS: Windows 8.1
Other PC is an AMD Athlon
2.2 Dual core with 2 gb ram and 500 GB HDD.
OS: Linux Mint
I just like old pc's :)
quintin1986
garyc, it is, once you jump back to dos from a modern windows interface, some stuff comes back to a person, and some stuff you have to learn again that you forgot.
Heh, I can't blame him. I still have one of my favourite PCs, quintin1986 should quite like it:
Celeron 300A @ 504 MHz
Abit BH-6 motherboard
192 MB PC-133 and PC-166 RAM
6.4 GB + 80 GB HDDs
2x Voodoo 2000 in SLI
S3 Virge Trio64 1 MB
21" Dell 2048x1536 CRT monitor
Windows 98 SE
:D
