Gprs connection problems
Spamhater
Im using my cellphone as a modem via my laptop .Im having very slow speed am i the only one having this problem.Reboot my computer three times this evening.
ibanez
Slow GPRS
Me to - there seems to be a problem with the DNS server my router is using; fixed by a reboot every 3min or so.
--snip--
Pinging 196.207.40.165 with 32 bytes of data:
Reply from 196.207.40.165: bytes=32 time=677ms TTL=126
Reply from 196.207.40.165: bytes=32 time=754ms TTL=126
Reply from 196.207.40.165: bytes=32 time=431ms TTL=126
Reply from 196.207.40.165: bytes=32 time=675ms TTL=126
Reply from 196.207.40.165: bytes=32 time=1028ms TTL=126
Reply from 196.207.40.165: bytes=32 time=964ms TTL=126
Reply from 196.207.40.165: bytes=32 time=829ms TTL=126
Reply from 196.207.40.165: bytes=32 time=519ms TTL=126
Reply from 196.207.40.165: bytes=32 time=561ms TTL=126
Reply from 196.207.40.165: bytes=32 time=617ms TTL=126
Reply from 196.207.40.165: bytes=32 time=717ms TTL=126
Reply from 196.207.40.165: bytes=32 time=534ms TTL=126
Reply from 196.207.40.165: bytes=32 time=610ms TTL=126
Reply from 196.207.40.165: bytes=32 time=673ms TTL=126
Reply from 196.207.40.165: bytes=32 time=749ms TTL=126
Reply from 196.207.40.165: bytes=32 time=589ms TTL=126
Reply from 196.207.40.165: bytes=32 time=625ms TTL=126
Reply from 196.207.40.165: bytes=32 time=686ms TTL=126
Reply from 196.207.40.165: bytes=32 time=808ms TTL=126
Reply from 196.207.40.165: bytes=32 time=624ms TTL=126
Reply from 196.207.40.165: bytes=32 time=523ms TTL=126
Reply from 196.207.40.165: bytes=32 time=563ms TTL=126
Reply from 196.207.40.165: bytes=32 time=615ms TTL=126
Reply from 196.207.40.165: bytes=32 time=719ms TTL=126
Reply from 196.207.40.165: bytes=32 time=575ms TTL=126
Reply from 196.207.40.165: bytes=32 time=614ms TTL=126
Reply from 196.207.40.165: bytes=32 time=652ms TTL=126
Reply from 196.207.40.165: bytes=32 time=707ms TTL=126
Reply from 196.207.40.165: bytes=32 time=748ms TTL=126
Reply from 196.207.40.165: bytes=32 time=664ms TTL=126
Reply from 196.207.40.165: bytes=32 time=342ms TTL=126
Reply from 196.207.40.165: bytes=32 time=600ms TTL=126
Reply from 196.207.40.165: bytes=32 time=641ms TTL=126
Reply from 196.207.40.165: bytes=32 time=721ms TTL=126
Reply from 196.207.40.165: bytes=32 time=533ms TTL=126
Reply from 196.207.40.165: bytes=32 time=592ms TTL=126
Reply from 196.207.40.165: bytes=32 time=909ms TTL=126
Reply from 196.207.40.165: bytes=32 time=888ms TTL=126
Reply from 196.207.40.165: bytes=32 time=1026ms TTL=126
Reply from 196.207.40.165: bytes=32 time=758ms TTL=126
Reply from 196.207.40.165: bytes=32 time=716ms TTL=126
Reply from 196.207.40.165: bytes=32 time=555ms TTL=126
Reply from 196.207.40.165: bytes=32 time=688ms TTL=126
Reply from 196.207.40.165: bytes=32 time=349ms TTL=126
Reply from 196.207.40.165: bytes=32 time=587ms TTL=126
Reply from 196.207.40.165: bytes=32 time=1157ms TTL=126
Reply from 196.207.40.165: bytes=32 time=1173ms TTL=126
Reply from 196.207.40.165: bytes=32 time=1443ms TTL=126
Reply from 196.207.40.165: bytes=32 time=1396ms TTL=126
Reply from 196.207.40.165: bytes=32 time=775ms TTL=126
Reply from 196.207.40.165: bytes=32 time=1311ms TTL=126
Reply from 196.207.40.165: bytes=32 time=1479ms TTL=126
Reply from 196.207.40.165: bytes=32 time=1224ms TTL=126
Reply from 196.207.40.165: bytes=32 time=1817ms TTL=126
Reply from 196.207.40.165: bytes=32 time=1063ms TTL=126
Reply from 196.207.40.165: bytes=32 time=1726ms TTL=126
Reply from 196.207.40.165: bytes=32 time=1110ms TTL=126
Reply from 196.207.40.165: bytes=32 time=824ms TTL=126
Reply from 196.207.40.165: bytes=32 time=613ms TTL=126
Reply from 196.207.40.165: bytes=32 time=552ms TTL=126
Reply from 196.207.40.165: bytes=32 time=1471ms TTL=126
Reply from 196.207.40.165: bytes=32 time=1217ms TTL=126
Reply from 196.207.40.165: bytes=32 time=1379ms TTL=126
Reply from 196.207.40.165: bytes=32 time=997ms TTL=126
Reply from 196.207.40.165: bytes=32 time=1273ms TTL=126
Reply from 196.207.40.165: bytes=32 time=759ms TTL=126
Reply from 196.207.40.165: bytes=32 time=1215ms TTL=126
Reply from 196.207.40.165: bytes=32 time=1441ms TTL=126
Reply from 196.207.40.165: bytes=32 time=702ms TTL=126
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Reply from 196.207.40.165: bytes=32 time=3431ms TTL=126
Request timed out.
Reply from 196.207.40.165: bytes=32 time=3947ms TTL=126
Reply from 196.207.40.165: bytes=32 time=2579ms TTL=126
Reply from 196.207.40.165: bytes=32 time=2434ms TTL=126
Reply from 196.207.40.165: bytes=32 time=3099ms TTL=126
Reply from 196.207.40.165: bytes=32 time=4196ms TTL=126
Reply from 196.207.40.165: bytes=32 time=3406ms TTL=126
Reply from 196.207.40.165: bytes=32 time=3766ms TTL=126
Reply from 196.207.40.165: bytes=32 time=1940ms TTL=126
Reply from 196.207.40.165: bytes=32 time=4444ms TTL=126
Request timed out.
Request timed out.
Request timed out.
Request timed out.
AirWolf
are you in 3g coverage area as per map on vodacom website? You may still pick up 3g outside coverage area but as more people connect in official coverage area you get kicked off the grid onto a gprs connection
ibanez
No, I'm on a farm using EDGE/GPRS datacard in pc; no 3G or HSDPA here.
Pico_Train
Ibanez, I am also on a farm near you. Make sure your phone is getting good reception from the tower. My speed is amazingly better doing this for obvious reasons.
Hope I am not saying something you already know...
Try moving around the house/office to connect to a different tower near you, you might also get better speeds this way. I get double the speed from the tower I reach from the back of my house compared to the tower I reach at the front. Bluetooth is rather helpful for this...
ibanez
Pico Train,
I've a complete investment in the Vodacom solution: HSDPA adapter, Linksys router, Poynting antenna.
My signal strength is 100% but only get EDGE/GPRS connectivity (speeds are more like GPRS+).
Where are you located? Pls PM me; I can send you more info regarding my DNS problems..
