Headphones for R450 or less
Devill
Damned
Hello All
I am looking to buy a set up headphones for no more than R450.
I would like some advise as I am not extremely knowledgeable in this department.
Things they must be able to do:
Block out most external noise (will be studying with them).
Have good to great sound quality
Fit over my ears and be comfortable.
I am in the Cape Town area (More specifically, Durbanville).
Any suggestions will be appreciated.
Maverick Jester
The Special One
To be honest, you won't get much for that price... But, saying this, Musica offer a decent set of Sony cans. Can't remember the exact model name and code, but I do remember them going for R450. A friend had a pair, and they match your requirements.
Unless, by luck, you are able to find someone willing to part with their Sennheiser HD202's. A rather decent budget headphone.
cerebus
How sensitive are you to accuracy at the mids?
This wins hands-down!
I had the hd202s for a while and wasn't impressed. They leak awfully and don't have a good fit on my head. And I couldn't even say the audio was that great.
Maverick Jester
The Special One
I experience the exact opposite, and I didn't expect them to be any good...
genetic
Mine work great. I use them via an Alesis io|14 Firewire sound card. Audio is crisp, and bass is good. There isn't anything in the price category that can match them.
EmileS
Oh, I never tried them before. Since I require a mic. But, people always mention it as a cheap headies to get? Maybe because the more expensive options are that good.
What else is their in this pricerange?
cerebus
Okay so I'm a lone sparrow on a rooftop with my displeasure over the 202s.
cerebus
Do you have an alternative for R450-R500?
I haven't gone enough in depth. The 202s are fine cans but I found the fit to be quite loose for one, and secondly - and much more importantly - the 3m cable was tremendously inconvenient for active wear. I always had to tie it in a knot to keep from dragging out of my pocket. If you intend to use them in anything other than a sedentary context you'll find that their bulk and the cable length annoy you.
how about the Behringers?
http://www.a1sound.co.za/pHPS5000/BEHRINGER-Closed-Type-High-Performance-Studio-HeadPhones.aspx
