Don't place hot things directly on the counter top...Hi. I'm planning to build my own solid wood kitchen counter top. Any recommendations of sealer/coating to use to protect the wood from heat eg. hot pot/pan, etc. placed directly on the counter?
This. No sealer/coating is that heat resistant. Maybe consider counter sinking a slate or marble slab flush with in the counter for that purpose.Don't place hot things directly on the counter top...
Could just go for a slate or marble counter too I suppose.Well, technically a ceramic coating would work, but then what is the point of using wood, also it would crack as the wood moves.
Ja, last counter top/s you'll ever buy. I wonder what the price difference between that and solid wood is these days.Quite honestly the best choice, looks good and endlessly durable.
Any real wood should be able to handle the heat without issues. It is mostly the varnish that will be a problem. So rather check the varnish or sealer you want to use and that it won't leave water marks or get damaged by heat.Hi. I'm planning to build my own solid wood kitchen counter top. Any recommendations of sealer/coating to use to protect the wood from heat eg. hot pot/pan, etc. placed directly on the counter?
I'm honestly not sure where you got this idea from. Wood is really not known for it's heat resistant properties. Aside from the fact that I burnt a bag of real wood this weekend, I don't think I've ever seen an old wooden countertop or kitchen table without a pan sized half moon scorched into it.Any real wood should be able to handle the heat without issues. It is mostly the varnish that will be a problem. So rather check the varnish or sealer you want to use and that it won't leave water marks or get damaged by heat.
Woodoc Food for Wood
www.woodoc.com
Well of course you are not going to start a fire on it. That is just pathetic. If something is scorching hot you will put it on a grill or coaster or something.I'm honestly not sure where you got this idea from. Wood is really not known for it's heat resistant properties. Aside from the fact that I burnt a bag of real wood this weekend, I don't think I've ever seen an old wooden countertop or kitchen table without a pan sized half moon scorched into it.
So in other words your answer to how can you protect a wooden counter from a hot pan being placed on it, is don't place a hot pan on it? Thanks for your contribution.Well of course you are not going to start a fire on it. That is just pathetic. If something is scorching hot you will put it on a grill or coaster or something.
You can place a warm pan on it or a warm oven dish.So in other words your answer to how can you protect a wooden counter from a hot pan being placed on it, is don't place a hot pan on it? Thanks for your contribution.![]()
How about a room temperature one?You can place a warm pan on it or a warm oven dish.
Don't get triggered. The OP asked about putting a hot pan on a wooden countertop.
and easy to keep cleanQuite honestly the best choice, looks good and endlessly durable.
